928 Forum 1978-1995
Sponsored by: 928 Specialists
Spacer Question
Old May 29, 2006 | 05:59 PM
George Boss's Avatar
George Boss
Default Spacer Question
So.......
After recieving multiple answers on my question about putting 993 rims on an 88 S4, the overwhelming response was that the rears will fit perfectly and the fronts will have to move out 1/2". The 993 rims are stamped 7 and 55 for the front, and 9 and 55 for the rear. Now knowing that the first number represents the width and the second number represents the offset, I now know that the rears from the 993 will fit perfectly the rear of the S4. The only trouble is, the front of an S4 has an offset of 65, and this, specific to the 928.
So the silly question is, can I put 10 mm (1/2") spacers on the front and use the 993 rims up there? Will I have any issues with the stock tires?
Old May 29, 2006 | 07:19 PM
Jim M.'s Avatar
Jim M.
Sorry George Boss, but adding a 10mm spacer will be the same as making the offset 45 instead of the current 55mm. In other words, the tire/wheel assembly will be sticking out of the wheel well 10mm more than originally, adding the spacer will make it stick out 20mm. The other thing is that the 7" rim is really to narrow for the 928. If you put 225's on the front ( the stock tire size for your 88) it should have a minimum of 7.5" wheel. It's been done before and the tire stays on the rim but it negatively effects tire wear and handling.
Jim Mayzurk
93 GTS 5-spd
Old May 29, 2006 | 08:41 PM
George Boss
So what is the solution if I want to run 17's? Do I buy aftermarket rim$ for the shark, or is there an alternative?
Old May 30, 2006 | 01:40 AM
redpathtribe's Avatar
redpathtribe
A number of owners are running 7" 993 wheels up front with 225's. I haven't heard that it is that big a problem. Yes 7.5" is better (8" is even better yet , but I'm still looking for a pair )
There is an excellent article about this on the Australia 928 web site, see:
http://www.landsharkoz.com/forms/928wheels.pdf
for a discussion exactly about this issue towards the end of the article.
On my GT when I put on 993 wheels, I had a 6mm spacer on the rear and was ready to go with a 15mm bolt on spacer before I got my 19" 997 wheels.
Rick Redpath
90 928 GT, Guards Red, Black/Grey
Old May 30, 2006 | 05:35 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
A 7" 55 offset in front should fit fine. Lot's of 993 wheels on 928s.
Old May 30, 2006 | 09:54 AM
George Boss
Isn't the offset for the front of a 928 65mm? If so, a 55mm offset shouldn't fit, right?
Old May 30, 2006 | 10:37 AM
Art_Z's Avatar
Art_Z
it will fit, esepcially an 8" one.
as far as the rears go, 19mm spacers for my 997 wheels (11" wide , 67mm offset) didnt do squat, I have to get 2" spacers to really be able to clear the inside of the body. at that point, i'll also be rolling the fenders. the 2" spacers should be here any day
Old May 30, 2006 | 02:08 PM
George Boss
So.....
I take my 7 x 17 55mm front 993 rims and my 9 x 17 55mm rear 993 rims, buy some rubber (what? 205/50/17 and 255/40/17?), put them on the shark as is, and away we go?
Old May 30, 2006 | 02:28 PM
James-man's Avatar
James-man
You will want 225s on those 7" wide fronts.
Old May 30, 2006 | 02:52 PM
George Boss
Thanks James!
So 225/50/17 front and 255/40/17 rear on the rims as is, right?
Old May 30, 2006 | 03:13 PM
SeanR's Avatar
SeanR
Mine are 17x7x55 225/45/17's on front, 17/9/55 255/40/17's on the rear and there are not problems.
