928 Forum 1978-1995
Sponsored by: 928 Specialists
Another Victory
Old May 23, 2006 | 01:11 PM
AJK's Avatar
AJK
Default Another Victory
Another big thanks to Rennlist. Pulled the cruise control brain and re-flowed all the connections on the bottom of the board. (as has been suggested in many posts) To be honest, none of the joints looked bad to begin with and after I was done they actually looked worse. I had to remove some solder bridges I had created and frankly I was concerned that I had done more harm than good.
Test drive today and the cruise works like it used to. Sets right at the current speed, and stays there. I never would have thought to do this if not for this site.
Thanks again.
Old May 24, 2006 | 09:36 PM
BlueMaxx's Avatar
BlueMaxx
AJ where did you get the thread on thhis? I'd like to do the same. Are there proceedures some where?
Thanks;
Blue
Old May 24, 2006 | 10:18 PM
j.kenzie@sbcglobal.net's Avatar
Blue,
This is as good as I've seen. It didn't work for me but, law of averages, it probably will for you:
http://members.rennlist.com/sharkski...ugeGremlin.htm
Good luck,
Dave McK.
Old May 24, 2006 | 10:43 PM
pbarick167's Avatar
pbarick167
What have folks used to clean the varnish off the board before resolder? Acetone, MEK, paint thinner?
TIA
Paul
Old May 25, 2006 | 12:12 AM
cambria's Avatar
cambria
I think I read on a post that Berrymans work well with some cautions.
Old May 25, 2006 | 12:29 AM
AJK's Avatar
AJK
The thread listed above is the one I used. Also, though I hate to admit it, I did not clear off the varnish first. Did not realize that there was a coating until I was 1/2 thru it, so by then I said screw it.
Old May 25, 2006 | 03:41 AM
SharkSkin's Avatar
SharkSkin
Nice, AJ. Just saved yourself enough dough for a couple tanks of gas! BTW, yes, Berryman's worked on the varnish, but be careful about getting it on the component side of the board -- don't want to dissolve any plastic components! I'm adding a note to my web page about this -- it will get uploaded with the next update.
