928 Forum 1978-1995
Sponsored by: 928 Specialists
Oil Pressure Gauge Twitch
Old May 8, 2006 | 09:20 AM
DavidH's Avatar
DavidH
Default Oil Pressure Gauge Twitch
My oil pressure gauge used to peg to number five at start up--this was cured by replacing the sender.
Recently, the gauge once again pegs to number five at start up, but the needle will drop to only 3 when the car is shut off, and then will continue to twitch around the 3 mark. This continues until the digital display closes out after a minute or so and then the needle falls to zero.
I will be replacing the pod in the next few weeks, so any thoughts while I have the display out of the car?
Old May 8, 2006 | 11:17 AM
cfc928gt's Avatar
cfc928gt
David, pretty expensive part on an '89+ to have to keep replacing, BTDT. On my digital dash I was having trouble with my temp gauge. It would work fine then drop to zero. Couple good wacks on the side of the pod would restore it. I finally pulled my dash and discovered the problem. On the digital dashes the connections are just pressure tabs. I pulled the panel off and took a needle nosed pliers and sqweezed the connections together so they had better contact when it went back together and it works fine now. One word of caution, I pulled all the bulbs and wiped them clean and I had one display light not work after it was all reassembled. Bought a new bulb, put it in, reassembled and it still didn't work. Turns out that it wasn't seated exactly where it had been for the last 17 years and there must have been just enough oxidation on the board to keep it from making contact. I'm pretty good at pulling the dash out now.
Old May 8, 2006 | 01:35 PM
SharkSkin's Avatar
SharkSkin
Sender wire may have an intermittent partial short to ground...
10 Best Cars of Lake Placid Porsche Parade
Slideshow: The 10 Porsches I couldn't stop thinking about at Parade 2026
By Joe Kucinski | 2026-06-22 10:28:13
Porsche Celebrates 75 Years in the UK With Special Manual 911 GT3
Slideshow: Limited to 51 examples, the Earls Court 51 Edition pays tribute to the first Porsche displayed in Britain back in 1951.
By Verdad Gallardo | 2026-06-19 18:37:27
Porsche Taycan Gets 'Engaging' Updates For 2027: 9 Things to Know
Slideshow: Porsche's hoping to liven Taycan sales up with simulated driver engagement!
By Verdad Gallardo | 2026-06-17 14:36:56
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
