CIS engine harness "write up"
Hello.
I promised to do a write up on the CIS engine harness. I made it as a diagram on the paper with a pen and pencil, marking gauges of the wires, where what goes and length of the wires. Then I just made high resolution pics of the diagramm and now if I could post it, or send it over e-mail to someone to post, then there could be a write up...
All the sensors are 2-point Bosch connectors which you can get here. http://www.eagleday.com/electrical.html
If someone could post pics for me I would be gratefull,
thanks,
Klim
thanks,
Klim
Klim,
Send everything to me...I will post on my website...
You see, the thing is that the files I have are not the complete write up but just the diagram of the wire size, what connects whaat and the lenght of the wires... I planned to do a complete write up when somebody would post the pics here, I would write all the info explaining the diagramm under it. But nobody posted the pics so far![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
PM me your e-mail address, and make sure you have at least 6 megs of space...
Klim
Klim
klim ... see email.. we are getting closer. Will post everyone the link once complete...
Brad(checkmate1996) posted it on his website. Here is the link: http://www.netopsys.com/928/TipsNTri...ss/harness.htm
Hope you guys will find it helpfull,
Klim
Klim
I have redrawn this in auto cad so it will be a little more legible. The quality of the scan sucks but I neede a small file size to post. let me know if you want a clearer copy.
Awesome!!!!!!!
Thanks a lot, this makes a lot more sense...
The only thing that the circles on the ends should be different diamter.
As I go along I will try to update, maybe with pics of finished harness, and any troubles I ran into..
Thanks again for the help,
Klim
Klim
Also, I have discovered the difference of CIS engine harness from L-Jet one.
In CIS, there is 2 temp sensors using bosch connectors, and one without the bosch connector on the thermostat housing...
On L-Jet there are 3 temp sensors with bosch connectors and one without it.
It threw me off a little bit, becouse I ran out of wires for Aux Air regulator....
Ill update the written part as soon as I will sort it out completely...
Klim
Klim
Piccardo, I found one mistake in your review diagram: sensor 2 and 3 go not into box 6 but go into ground, which in fact is circluar connector, which is attached on the camtower.
The box 6 is on the alternator bunch, I just put it in there to be able to draw the type of terminal clearer.
Klim
Klim
