Help! CIS Fuel injector removal
Thanks Dennis,
I don't know what I would do without you I owe you one. I only messed up one on taking it out and that was the thread where the fule line goes. I might be able to straighten it out.
Cheers,
Frank Barnhill
Cheers,
Frank Barnhill
I wouldn't risk a bad seal unless you can find the right size die and retap it. If you do try to retap it, make sure you don't get shavings in the injector. BTW, I gave 6 or 7 used injectors to a local P car guy that was building a pressure cleaner. I'll try to contact him tomorrow.
Dennis
Dennis
Thanks Dennis that would be great. I could probably get away with one. I can buy one from 928 International or Spec for $20.00. I will if I have to but this job just keeps climbing in the $$$. "She" is already complaining...
Frank Barnhill
79 Euro
Frank Barnhill
79 Euro
Thank you Kim, any help would be appreciated. Dennis, I checked and the cap will still screw onto the injector. If I can't find another, I might try to use it.
Thanks,
Frank Barnhill
79 Euro
Thanks,
Frank Barnhill
79 Euro
