928 Forum 1978-1995
Sponsored by: 928 Specialists
Anyone has contact info for Andy Keel?
Old 04-27-2006, 02:20 PM
mspiegle
mspiegle's Avatar
Originally Posted by Bill Ball
Tarek:
When you locate him, please say hi to him for me and tell him my car is still running very well after over a year and 15k miles since the Supermodel install.
wow, you're catching up! Does anyone know who has the most mileage on a supermodel? I'm pretty sure i'm either first or second, but since I can't drive the car... someone's gonna catch me
Old 04-27-2006, 02:42 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Yeah, the car has been a dream to drive. The old rough idle problem went away when I moved the vacuum source for the bypass from the manifold to the throttle. Since then, no issues at all.
Old 04-27-2006, 02:57 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
But Bill you have that horrible smoke issue We still have tire marks in the street !
Old 04-27-2006, 05:18 PM
Tony
Tony's Avatar
Hey Bill Send me a pic or someting of that.
Thats the only little gremlin i have. Worse when warm.
Old 04-29-2006, 01:24 PM
PorKen
Inventor
PorKen's Avatar
eBay | Porsche 928 32V '85-'92 S, S4, GT Supercharger System
Old 04-29-2006, 01:39 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Tony:
Andy insisted the "vacuum" control source for the bypass valve be hooked to the manifold, after the SC. So, he T'd off the source used for the boost gauge. The bypass valve has its own vacuum source port built-in, which samples the pre-SC intake. Andy blocked that off with a bolt and made it impossible to use by routing the booster vacuum source immediately under it.
I just re-routed the bypass vacuum to one of the throttle body sources and blocked the T on the manifold. Instantly, the rough idle was gone. The valve still seems to operate as it should, closing when you step on the gas. Interestingly, on the dyno, this arrangement knocks down the early (2500-3000) torque peak, the one that everyone says is a TC multiplier artifact and should be ignored. Wonder if it might be better for tip-in, alhtough I've never had that issue and I'm not sure what thsi would do on a MT car.
The bypass valve is being controlled by throttle vacuum now and never see boost. It closes as the vacuum is reduced when the throttle opens. That's the way it was designed to be connected. I am not sure why Andy insisted on maifold pressure. Maybe he noticed the difference in the low RPM torque curves.
Anyway, try moving the source to throttle. The idle will smooth right out.
Anybody have any perspective on this?
Old 04-29-2006, 02:10 PM
FlyingDog
FlyingDog's Avatar
Hasn't the only 1 returned ever been sold a few times on ebay? Isn't Andy's name goridesno or something like that on ebay?
Old 04-29-2006, 02:45 PM
cfc928gt
cfc928gt's Avatar
Yep, that's the same auction that's been run from time to time. This is a SCAM!!!!
Old 04-29-2006, 03:04 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
New high bidder!
Old 04-29-2006, 03:07 PM
FlyingDog
FlyingDog's Avatar
How fast do you think we can hit $1,000,000? (In small increments of course.)
Old 04-29-2006, 03:13 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Another dead giveaway that this is fake is the category listing.
Toys & Hobbies > TV, Movie, Character Toys > Thomas the Tank Engine > Wooden > Other
Old 04-29-2006, 03:21 PM
FlyingDog
FlyingDog's Avatar
Haha, I didn't even look at that.
Old 04-29-2006, 11:17 PM
Tony
Tony's Avatar
Tony:
Thanks i will give that a try next week when i get to it.
Old 04-30-2006, 02:24 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Good, Tony. It only takes a minute, and the results are dramatic. At first it was 90% better. Now, it is 100%.
Old 05-13-2006, 03:30 PM
TAREK
TAREK's Avatar
I'm sad to say Andy continues to be MIA. If anyone in touch with him, please PLEASE PLEASE let him know I'm looking for him.
Thank you
Quick Reply: Anyone has contact info for Andy Keel?
