timing belt covers
HTML Code:
To remove the belt covers on my 81, the only part I have to remove is the dip-stick
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
I will not list how much stuff I have to remove; starts with the both radiator hoses....
Marton
Team Owner
the harmonic balancer is held on with the 27mm bolt so you need a deep 27mm and either a impact wrench or a flywheel locking tool and a big breaker bar, it is easier if you also remove the radiator and all of the cooling hoses in the front of the engine to work on things. Pay attention to how the numbers are on the damper as it can be fitted either way, the correct way is while viewing the engine standing in front of the car you should be able to read the numbers on the damper. Also make sure you orient the washer it has a step on it it is made to apply pressure to the other pulleys when its tight as the crank protrudes just a bit from the pulleys when there installed
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Team Owner
try soaking the shaft with some PB blaster and then try to wiggle the damper side to side a few taps with a hammer may help, once it is moving then it a matter of wiggling the damper till it slides off the crank
Yes, it is one of those things that you think will never come off. Do what was suggested, then you try to wiggle it with both hands; it does not move & then you feel an ever so slight barely perceptible movement that gets bigger & bigger and finally you have it off
Marton
Marton
