Replacement Sony speakers
Thought i'd share these pics. The speakers are standard Sony OE replacements with polyurethane cones that come with a variety of break away tabs allowing you to get good fixings. Best of all they look near to stock with the original grills fitted. I did the usual mod on the Bass... OE speaker removed and cut down to use the original ring to secure the new speaker. I decided to keep the original factory tweeter as I couldn't be bothered to change it, although a replacement was available. All in these cost approx £100.00 and after bypassing the factory Quadro amp sound fine - bit low on bass, but listenable when cranked up! (PO fitted new head unit with 4 x 25 RMS as opposed to the quadro 4 x 7RMS, but then ran the new head unit through the old Amp bringing the power back down.......some people do worry me!)
Stuart, bought them from Halfords, of the shelf sizes.
Try: http://www.sony.co.uk/view/ShowProdu...=ICA+Speakers#
or
similar: http://www.halfords.com/webapp/wcs/s...lectorGroupId=
or
Those 4" are 2 way. Did you bypass the factory crossovers? You could spray paint the cones black. That might make them look more like factory.
I was looking at these front mounted magnetic, low mounting depth, MB Quart model RUA 210:
http://www.cardomain.com/item/MBQRUA210
They should mount easy in the 4" spot on the rear quarters.
How can you tell if a PO bypassed the factory cross overs without opening up the interior? There were no speakers in the car when I bought it...just holes.
Also, i tried to find those sony xsa 1727 speakers here in the states but no luck. Anyone know if they are sold in the USA under a different model number? Thanks
1984 928 auto
1984 928 auto
