Power Bleeding the Brakes (not so good) UPDATE!!
#32
Supercharged
Originally Posted by FlyingDog
That's what hose clamps are for...
#33
You're right, they don't come that way. I launched my blue hose the first time I hooked up the power bleeder, but it was more of a purplish-black hose at that point. I have two FI hose clamps on the new one.
#34
On this topic ... inside my master cylinder there's a plastic cup that seems to be for the brake fluid level measuring system. Do you take that out of the way before hooking up the power bleeder?
#35
Originally Posted by Andrew Olson
I am not too impressed with the power bleeder for getting air out of the system. I just don't think it genereates enough pressure to get the air out. It's great for a flush or fluid change, but for getting air out I found using one of these $6 one-man bleeders works like a charm! The only issue is that there is a magnet on it so you can position the bottle higher than the bleeder screw. Front fenders are aluminum so I had to use a little clamp to hold it up. Other than that, $6 is a cheap tool to have for bleeding.
A very rare number of friends I speak to that have had difficulty pressure bleeding just didn't know enough about the process or were to stubborn to abandon their old process. These are my observations and I mean absolutely no disrespect to anyone.
#36
