Ball joint dirt and grease.
I pulled off the spindles to do my front ball joint and tie-rod boots. All the balljoints feel perfectly fine, passed the push on the wheel tests, and are tight but move smoothly without anything attached.
Some dirt has gotten into the boots on a few of them and some even reached the *****. Can I flush the joints out with anything or am I just going to push the dirt into places it shouldn't be? I've always read not to mix greases, so I need to figure out what's in them now. The grease is dark green. Are there any common dark green greases?
FWIW, the only dark green grease that I have ever used was, you guessed it not on a car but on a bicycle. Phil Wood Waterproof Grease.
http://www.philwood.com/Price%20List...andCleaner.pdf
You should cary a tube of it for all of your waterproof grease cycling needs.
I know, no help at all.
Michael
Michael
Supercharged
I'm not sure what's the best thing to clean them with, but I would think any kind of lube grease should be fine - even if they are different colros. Well, at least it never stopped me. Of course ignorance is bliss!
None of the dirt has really mixed with the grease around the *****. It's globs of dirt wrapped in grease resting against the *****. That is why I'm hoping a cleaning will avoid any problems.
