revised revision of interior door panels...
Owns the Streets
Needs Camber
Needs Camber
I'm seeing matching orange interior seat panels.
The panels 'tween the side bolsters.
I'm a sucker for 2 tone seats.
Ernest (NYC)
Ernest (NYC)
Cottage Industry Sponsor
Originally Posted by Jim bailey - 928 International
Those are comments from our resident interior designer ! who I believe is admittedly into modern minimalist. Excellent points however.
Originally Posted by Malibu310
The console is very "busy"... my plan is a simple perhaps metal panel eliminating seams painted same orange.
Now, if you can move that little switch panel with the AC and power lock switch underneath the AC controls, you have a more logical and ergonimic setup, where the more often used (audio/nav) elements are higher up and more in the driver's view, while the lesser used controls are further down without being out of view. The AC and door lock switches are rarely used while driving, so they can be last... Just a thought - not sure, if it's even possible.
Edit: Ooops - forgot that you have the RESET button there also. Well, that might be needed while driving, so the above might not be the most practical for your car.
Electron Wrangler
So maybe a bit like this then....
And no its not mine ...but it is a GTS - looks like they had a little trouble fitting th AC/lock panel at the top - a squeezed overlap - but AC looks good. Overall a good matching look I think (VW MFD System). Malibu has a similar layout I think the switch panel could go below the Nav or AC and there seems to be spare space below the AC in ths layout - the AC head may be to deep to go any lower though - the switch panel would fit in much less depth (I know the panel well). I think the reset switch is functional even there at the bottom.
Alan
Alan
