1985 ISV change
Glenn,
My recollection is that if you take off the air filter and its box and the MAF, you will be able to access it from the passenger side rear of the valley. There's not lots of room to work on it, but it can be done. Check that the hoses that attach to it are in good condition WYAIT. Just the 2 hoses,an electrical connection and a fastener to do if memory serves correct. Shouldn't take very long, barring unforseen problems.
Glenn
Glenn
I don't think so. One of the hoses from it goes to the throttle body; I suppose you could leave the hose attached at the throttle but there is no way to reach that clamp. You ought replace those hoses anyway. In order to get at the intake, the fuel rail has come off, that means careful prying and cursing to get the 4 injectors out. It's at least 4 hours, more like 8 for me. YMMV.
Ok, just to be more clear, the ISV can be changed without removing the manifold. I said "Check that the hoses that attach to it are in good condition". If they are fine, no problem. If the hose that goes to the throttle body needs replacement, as SteveG said things get a bit more complicated.
Glenn
Glenn
Dan
'86 928S 5-spd w/LSD
You know what ?? Pulling the 85-86 intake is no big deal either, and then, you can see and assess the condition of all hoses and clamps in there instead of playing "peek-a-boo" and hoping for the best. In my experience, the intake runner tube gaskets stay attached to the tubes, and do not require replacement, and the whole job is made simpler by having them out of the way, and you have access to the "notoriously cracked" 7 way vacuum fitting at the rear of the intake...and can paint or powder coat the intake plenums and runners while they are off etc.etc....in other words, its easy to pull the intake plenums and port runners, and check closely all the rubber couplers between the side plenums and the port runners, and the large couplers to the throttle body. These are prone to cracking with age, and lead to hard to diagnose vacuum leaks. and all the under the intake hoses should be carefully inspected and replaced if necessary...This way you do this job once, do it right, and don't have to get back in there anytime soon...unless you find out you have a screwdriver or wrench or something missing...after you have it buttoned back up.
