Head & Cam Cap Line Boring Specifications Needed
I have a set of S4 heads with mismatched cam caps. I need to get these line bored, and am wondering if anyone has the specifications on the diameter and length of the bore needed.
Thanks!
Thanks!
Thanks Adam, didn't even think to look there. I guess I can measure a head to figure out the length.
I have a local estimate to have this done for $400, does anyone know if this is good or bad?
I have a damaged cam cap too - and was wondering about this procedure. Would it not be necessary to grind down the mounting surfaces before boring? If not, I can't see how you would get any metal to bore from...
