New shoes- 11"Turbo twists with 295s
Got them in the mail today. Mounted them up with a good tug/pull on the rear fender lip then a light roll of the lip just in case.
PERFECT FIT!!
Quick test drive and its like night and day as far as traction vs my kuhmo 265s!! No rubbing.
Easy to clean and updated the car to an OEM "modern" look IMHO.
VERY happy and highly recomend![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
The RIVAs looked great also...just time for a change. Got a good deal on the wheels
PERFECT FIT!!
Administrator - "Tyson"
Very nice - I never really liked those wheels on 911's. They look perfect on the 928 - damn, silver 928, my dream shark.
Looks very nice. What size is the front? What are the offsets?
Front: 18x8 et 50 with Continental Sport Contact 2 tires 225-40ZR18
Rear: 18x11 et 45 same tires but 295-30 ZR18
Traction is "mo" better.
Still have to be careful, but MUCH better.
Those fronts would never fit my 79.
Looks good Tony.
I definitely found a huge difference from 255's being almost useless to having much more fun with sticky 295's.
Jim
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Jim
Originally Posted by IcemanG17
Tony
Very nice!!!! Are they hollow spokes?
No they arent. I was looking at a set but couldnt justify the cost over these WITH tires. I put this combo on the scales and the twist rims with the 295 Conti's are 3lbs heavier than the 10" Rivas with Toyo 275 RA1s/...57 lb vs 54 lbs.
I figure with the extra width of the rim and the larger tire...thats not too bad.
It all adds up yes, but i doubt i can feel the differnce in 3lbs per wheel with 422ftlbs of tq.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
thank Mike. Its not a show room, thats for sure. It gets a LOT of use..the digital pics make it look better. I will say the floor is holding up well after 2 + years. Defintiely not like the day it was set down, but way better than bare concrete.
Now, i wonder how long it will take until my wife notices the wheels
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
![](http://www.mercedesshop.com/shopforum/images/new_smilies/behead.gif)
Under the Lift
Amazing that 18x8 50 offset fits the front. Looks like they are out in the photo, but may tuck with suspension compression. My 17x7 52 barely fits.
Ill snap some pics of the front when i can, but they really dont stick out AT ALL.
really look good.
Btw, im running the bilstein/eibachs from 928intl if that helps. Ill have to check the ride height in a bit also.
FYI....i also noticed something about the twists that i never knew about before. Look at the picture below and think about either side of the car.
I should post it in the "did you know " thread.
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
