928 Forum 1978-1995
Sponsored by: 928 Specialists
Throttle response lag - hmmmm
Old 04-02-2006, 09:06 AM
kary4th
kary4th's Avatar
Default Throttle response lag - hmmmm
When hitting the accelerator, there's a significant lag in response.
I'm assuming it's a vacuum hose issue, but what else should I consider?
I hate making multiple trips to the auto parts store (24 miles round trip to the nearest Napa - ain't rural life great!).
Old 04-02-2006, 02:11 PM
SharkSkin
SharkSkin's Avatar
Is your timing set per spec? See if the mechanical advance in the distributor is functioning smoothly. Also check the vacuum pot operation. Also, IIRC euros had two vac lines to the distributor. Could you have switched them?
Old 04-02-2006, 04:29 PM
kary4th
kary4th's Avatar
I'll check all these things. Once again, thanks for the tips, Dave.
Old 04-02-2006, 06:05 PM
heinrich
928 Collector
heinrich's Avatar
I'd say vac leak
Quick Reply: Throttle response lag - hmmmm
