928 Forum 1978-1995
Sponsored by: 928 Specialists
I found a replacement engine!
Old Mar 31, 2006 | 01:18 PM
SharkSkin's Avatar
SharkSkin
Way to go, Brent! May the BWAAAHHH be with you!
Old Mar 31, 2006 | 04:05 PM
FeedNfrenZ's Avatar
FeedNfrenZ
No, it didn't come from south Louisiana. Where do I find the serial number?
Old Mar 31, 2006 | 04:51 PM
FeedNfrenZ's Avatar
FeedNfrenZ
HOLD THE PHONE!!!!!!!!!! What seems to be too good to be true usually is!
Went roll the crank with a ratchet, turned easy......... I little too easy! Then I noticed that the cams weren't turning. Pulled the timing belt cover YEP! the other kind of TBF (Timing Belt Failure). What are the odds that the block is still good???????????????
BTW I only paid $300 for the whole thing!
Old Mar 31, 2006 | 04:53 PM
Jim bailey - 928 International's Avatar
The block should be fine, pistons probably are fine as well.
Old Mar 31, 2006 | 04:57 PM
James-man's Avatar
James-man
Brent, you still won! Still a score!
Sure you gotta throw some new parts into the damaged engine, but then you will know it's condition is good inside and out and not have to wonder.
Good luck with the rebuild!
Old Mar 31, 2006 | 05:15 PM
Jim_H's Avatar
Jim_H
Absolutely.
Old Mar 31, 2006 | 06:41 PM
FeedNfrenZ's Avatar
FeedNfrenZ
Thanks guys for the words of encouragment!
Old Apr 1, 2006 | 01:33 AM
SharkSkin's Avatar
SharkSkin
Well, OK, wrench a little more, then BWWAAAHHH!
Old Apr 1, 2006 | 07:04 AM
John Veninger's Avatar
John Veninger
Brent,
Want to sell me those 89 heads with the bent valves?
Old Apr 1, 2006 | 09:33 AM
heinrich's Avatar
heinrich
928 Collector
Brent I'd be interested in the heads also. Bet I can beat JV's offer.
Old Apr 1, 2006 | 11:07 AM
Jim_H's Avatar
Jim_H
Old Apr 1, 2006 | 11:32 AM
NickT's Avatar
NickT
You trying to build Frankenstein now??? Parts from here and there . . .
Old Apr 1, 2006 | 11:38 AM
heinrich's Avatar
heinrich
928 Collector
Nick I have an 89 with no engine, so authentic 89 parts would be good
Old Apr 1, 2006 | 02:27 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Heinrich,
How many 928 do you eaxactly have? For the last couple years I've noticed that you tend to buy up evrythign that is a good deal. You must have a fleet of 928 to require that many parts!
Brent,
You can pull out the spark plugs and with a flash light take alook at the top of each pistons. I'm pretty sure it is still good. Do you know if the engine came form an auto or 5-spedd? If it was an auto the short block will be fine is not, you need to pull it apart and look at it. Either way, for $300 it's one heck of a find
Old Apr 1, 2006 | 03:13 PM
heinrich's Avatar
heinrich
928 Collector
Imo, I have a floating collection, I enjoy buying and restoring easy fixes ... I used to be into 944's and the first couple of 928's were just for driving, but then I started looking for wrecks or cheapies for parts as parts were so expensive. Well, the first one needed just a windshield and fender and some lights. The next needed a tbelt job. The next also. The next needed a tie rod and so-on ..... I can't even bring myself to break the 80 I got from Porken because it hasno sunroof and as an 80 is emissions exempt!!
