928 Forum 1978-1995
Sponsored by: 928 Specialists
Oil Filler Sludge
Old Mar 31, 2006 | 12:27 PM
  #31
BC's Avatar
BC
I don't think there is much to lose in trying to drive or at least rev it to see if it changes.
Old Mar 31, 2006 | 12:37 PM
  #32
heinrich's Avatar
heinrich
928 Collector
Well we could be looking at a good crank, rods, pistons, block with just a bad rod bearing. If we revved or ran her, we might break the rod end; damage the crank; push the rod through the side of the block .... no?
Old Mar 31, 2006 | 12:55 PM
  #33
heinrich's Avatar
heinrich
928 Collector
Very cool input Gentlemen .... we'll take a look when I can personally see her .... I look forward to it. I need to get that rear glass from Dozman methinks....
Originally Posted by s928s
THat is excess engine oil sludge. I see that alot in the TOYOTA's I that come in on a day to day basis ( 3.0 v-6 ) camry, solara, sienna, ect . mainly comes from high cylinder temps and lack of oil canges at a regular interval, When you see it at the upper end, Its is usally worse at the lower end. The oil passages get restricted as well as the oil pick-up. Oil starvation starts and Its all down hill from there.
With the Toyota It started when they switched from Iron block to an all aluminum block and eliminated the oil cooler.Also the pcv chanber in the valve covers were redesigned. I guess they felt the aluminum would be a cooler engine, That coupled with the forgetfull people who did not changed their oil reguarly caused the oil to "gell". There is a sort of "silent campaign" still going on through toyota for those veh. If it is "gelled" through toyota, I just takes "proof" of 1 "lof" per year as proof of maint and the dealer is self authorized. they will replace the valve covers, desludge the upper end, valve seals, pull oil pan and desludge.
Hendrich, Not having the service hostory of the car, expecially with lose mileage the sludge could be normal engine oil break down. the PO may have only changed the oil at the factory recommended intervals...for some of us that is several years if we trac by miles. The quality of the oil also plays a role.
Old Mar 31, 2006 | 01:48 PM
  #34
Steve J.'s Avatar
Steve J.
I'll be the optimist here and suggest that the knock is only a stuck hydraulic lifter. A little liquid therapy with the proper fluids and she might clear right up.
Old Mar 31, 2006 | 01:51 PM
  #35
heinrich's Avatar
heinrich
928 Collector
... thanks Steve. Well Rog says it is definitely not a tack-tack (flywheel) or tick-tick (lifters), but more of a knock-knock, and he says it is so loud you definitely do not want to start her up. To me this means something more serious than the many many head noises and such I have heard. But ... we never know, and are eternally hopeful
Old Mar 31, 2006 | 02:17 PM
  #36
Tom. M's Avatar
Tom. M
Deleted
25 Year Member
Actually.....Rob Fossett had a nice knock knock sound on his 85 928...a while back...usually present when cold on startup.....
Turns out it was a bad waterpump..shaft moving in and out..perhaps a peek to see what the belt is doing....
could be as simple as a new waterpump..
Good luck,
Tom
89GT
Old Mar 31, 2006 | 03:09 PM
  #37
heinrich's Avatar
heinrich
928 Collector
Hmmm ... we'll check, thanks Tom
Old Mar 31, 2006 | 04:22 PM
  #38
Dave Howerdel's Avatar
Dave Howerdel
When the rod bearing went on the 86 I had, I distinctly remember the sound reminded me of the sound that Bogey's steamboat made in the movie African Queen. Yeah, just call me strange.
Old Mar 31, 2006 | 06:45 PM
  #39
Thaddeus's Avatar
Thaddeus
Deer Slayer
Did it, Mr Ullknott?
