Radiator repair
Radiator repair
I just got my radiator back from a shop they told me they could not fix it. I bought this car with the infamous hole where the headlight motor arm pushed through.
They said they cant fix it because it was alluminum. Is there a way to fix this? I have 3 torn tubes and they are rolled over and crimped. thanks.
Sorry to hear it. I thought I had to replace the side tank seals due to a leak but it was really the hose clamp was the problem. After I did all repairs oh well I have new seals. Sounds like possible aluminum radiator from Devek or one of the others. Good luck.
The Parts Whisperer
http://www.mailordercentral.com/928i...s.asp?dept=113
This just happened to me. We're sure the rad can't be fixed?
Also, I have an 86 5-speed. There's no oil cooler on that stock, right? So if I were to order a new rad I'd want the 'no cooler' version?
Sigh.
Sigh.
928 Collector
One way is to remove both end tanks and weld shut the 3 damaged tubes. Another alternative is a new or used radiator from us.
