Porken's 16V cam timing tool
#46
My compression is a bit higher than stock but then again, the engine has a good quensh and the chamber has been polished for the removal of hot spots. As I mentioned we run 98 octane here so that is bit of a help too. I will go back and read the thread entirely, just been quite busy. Does it help at all on full power?
Thanks Greg
P.S have you got a production run for the early cars yet Ken?
Thanks Greg
#47
Inventor
Production run of what?
#49
Inventor
Inventor
Round tooth (HTD) iza vatta you vant. Kapeesh?
Originally Posted by PorKen
83-84 (83-86 euro) need:
(2) HTD 32V cam gears - sprocket – 928.105.530.01 or 928.105.530.00
78-82 also need:
(1) HTD oil pump gear - oil pump sprocket – 928.107.107.13
(1) HTD crankshaft gear - crank sprocket – 928.105.125.12
(1) HTD timing belt – timing belt – 928.105.157.50
78-82 also need:
#52
so, tohk to me... what's the scoop
#53
Inventor
Click on the pic above, and order a kit based on new or used hubs. Then order some new or good used 32V gears.
