928 Forum 1978-1995
Sponsored by: 928 Specialists
Flappy experts, need help
Old Mar 13, 2006 | 06:01 PM
Peter F's Avatar
Peter F
Default Flappy experts, need help
I have started to pull my intake to exchange the flappy bearings due to a leakage after powder coating.
Can some one tell how many turns pretention there should be on the spring that makes the flappy close after operation?
Not sure that i made it right the first time intake was off.
/Peter
Old Mar 13, 2006 | 06:06 PM
heinrich's Avatar
heinrich
928 Collector
IIRC 3. VERY tight.
Old Mar 13, 2006 | 06:13 PM
borland's Avatar
borland
Old Mar 13, 2006 | 09:14 PM
cambria's Avatar
cambria
When I put mine back togeather, I had so tight that I could not open the valve by sucking on the tube. So I adjusted the flappy so I could open it with my mouth. I looked everywhere in the WSM as to how to install but nothing. As I recall there is one turn on the spring from working and not. So I am as interested as Peter as to the correct way to install the flappy valve.
Old Mar 14, 2006 | 09:16 AM
Peter F's Avatar
Peter F
Thanks Heinrich,
so three turns should be taking me back to factory default?
Good picture Borland but gives no insight to the pretension mystery.
Cheers/Peter
Old Mar 14, 2006 | 10:43 AM
the flyin' scotsman's Avatar
the flyin' scotsman
Peter..........the car develops somewhere between 15 -20"Hg so set the spring tension so that you can open the flappy valve with a hand vacuum pump at this level of vac.
