Thanks RedUFO....Sub Box....
I am just finishing the same thing except with a 12 sub. The only difference is I did not make a box. I used the spare well as the box by installing a rubber weather stripping to the bottom of the 3/4 plywood and redid the hold down clamps. It works very well, so do not build a box just a shelf.
Originally Posted by dr bob
To make the carpet surface look more even, consider a layer of 1" foam, cut to fit around the "protrusion" where the speaker box sits a little high. The carpet will appear to be flat, and you may appreciate a little extra sound deadening. Alternately, stack layers of carpet pad (off the roll at Home Depot) to make up the height difference.
I'm thinkin' that the downside to any raising of the overall carpet height is that the cargo cover hard point attachments are then no longer protruding above the carpet height.
