928 Forum 1978-1995
Sponsored by: 928 Specialists
AFM adjustment
Old Mar 8, 2006 | 02:07 PM
icsmike's Avatar
icsmike
Default AFM adjustment
I got a used afm from a running car and someone for some reason turned the adjustment all the way one direction. Is this gonna be hard to figure out where it needs to be? 86.5 Thanks.
Old Mar 8, 2006 | 02:13 PM
John Speake's Avatar
John Speake
Hi
The pot should have no end stops, but it doesn't like being screwed past the end of the track.
Measure between pin 6 and case, and turn the pot to get a resistance of 300 ohms. Try anticlockwise first. The pot is 20 turns, end to end.
Old Mar 8, 2006 | 06:33 PM
icsmike's Avatar
icsmike
Thanks for the info. Can you put that in dummy terms? lol
Old Mar 9, 2006 | 06:29 AM
John Speake
If you don't have a multimeter, ask a friend :-)
Old Mar 9, 2006 | 12:59 PM
Lorenfb's Avatar
Lorenfb
The best way to adjust an AFM is with the use of a gas analyzer and monitoring
the CO level. The AFM spring is adjusted for a CO of about 1.5% at about 2000
RPMs, with the engine warm & O2 sensor disconnected. The throttle response
of the engine can be improved by tweaking the position of the thick-film wiper
arm & the spring tension.
Old Mar 9, 2006 | 01:11 PM
John Speake
Hi Loren,
An 86.5 has a hot wire MAF, not a barn door type... :-)
Old Mar 9, 2006 | 03:46 PM
Lorenfb's Avatar
Lorenfb
"An 86.5 has a hot wire MAF, not a barn door type.."
Didn't say that, did I?
The poster posted AFM which is NOT the same as a MAF which MANY continually
confuse and thus the responding post was based on what was posted, i.e. an AFM.
Many need to CORRECTLY use the appropriate terms.
Check here ( www.systemsc.com/glossary.htm ) when in doubt about appropriate terms.
Furthermore, whether it's an AFM or MAF (if adjustable), both need to
be set properly with a CO meter!
