928 Forum 1978-1995
Sponsored by: 928 Specialists
all Aluminum radiator- 928 International
Old 03-07-2006, 04:49 PM
Carl Fausett
Developer
Carl Fausett's Avatar
Default Its a quality unit and looks great installed
A recent customer sent me these...
Old 03-07-2006, 04:54 PM
m21sniper
m21sniper's Avatar
Looks pretty much just like mine.
I wonder who made the one in my shark. At any rate, very nice.
Old 03-07-2006, 05:45 PM
Tom. M
Deleted
Tom. M's Avatar
Interesting pic Carl...so why is the coolant reservoir on the drivers side?..Is this a UK or Aussie car?.
Interesting...but nice rad for sure..
Later,
Tom
89GT
Old 03-08-2006, 07:14 PM
NickT
NickT's Avatar
I think my car read this thread. It's second radiator (rebuild) sprung a bad leak the other day... Just ordered the C&R rad from 928 International....
Thanks guys!!
Old 03-08-2006, 07:56 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
At present we are not able to communicate directly with the cars...but we are working on it
Old 03-11-2006, 10:01 AM
S4pilot
S4pilot's Avatar
Hey guys! Guess what? My radiator was leaking on the passenger side, so I ordered a tank and seal from 928 International... then the tabs broke while trying to have it installed. Oh well! Loooks l;ike I will be ordering a radiator from them !
Old 03-11-2006, 10:52 AM
ew928
Owns the Streets
Needs Camber
ew928's Avatar
Jim,
You mean you haven't gotten the 'Easy' button ready for
pod or dash mount yet?
Ernest (NYC) Used Behr from 928Int'l with fresh side tank seals.
Old 03-11-2006, 05:23 PM
NickT
NickT's Avatar
Has anyone put the C&R radiator in yet? I test fitted mine and it's evident that the overflow nipple on the drivers side is an inch higher that what it would be on the stock Behr radiator. The hood won't close like this. The only way out I see is to remove the rubber mounts at the bottom. This will lower the radiator about an inch so the overflow line will clear the hood, but that will also lower the fan assembly and leave a gap between it and the hood and not have any shock mounting for the radiator. Not sure on how to proceed.
It would have been better if the overflow tube came out the front of the side tank, not the top.
Old 03-11-2006, 05:54 PM
SharkSkin
SharkSkin's Avatar
Are you sure the bottom rubber mounts are seated properly in the grooves in the rad? When I installed my Devek radiator I almost resorted to trimming the sides of the rubber bumpers to fit into the groove in the rad, but I managed to rotate them to a position where they would fit into the groove. They were a bit oval-shaped. I don't recall whether they can be loosened and moved around like the top ones, but you might look into that. As a last resort, you might consider cutting the bottom rubber pieces, but you need as much cushioning as you can get down there IMHO and should double-check clearances, especially for the sheet metal screws that attach the front lip of the belly pan and protrude toward the bottom edge of the radiator. Doesn't sound right.
Old 03-11-2006, 06:05 PM
NickT
NickT's Avatar
The C&R is 17 5/8 inches from the bottom to the top of the nipple. The stock Behr is 16 7/8 inches. If you look at the picture above, the bottom of the nipple is 1/2 above the deck of the radiator. On the Behr, it's 1/2 below the top deck. I'm going to see if I can find a 90 degree fitting to use istead of the nipple.
Old 03-11-2006, 06:18 PM
SharkSkin
SharkSkin's Avatar
Ouch... are you measuring from the very bottom of the rad or the lower mount point? It's the latter that is most important...
Old 03-11-2006, 06:33 PM
NickT
NickT's Avatar
Mount point to the top of the nipple... There is no way the hood can close. The cross bar on the hood is right above the nipple as well, so no head room so to speak.
Old 03-11-2006, 06:38 PM
SharkSkin
SharkSkin's Avatar
Well, if a 90° fitting won't cure it, I'd say a phone call is in order....
Old 03-11-2006, 06:43 PM
NickT
NickT's Avatar
this is what it looks like...
Old 03-12-2006, 01:57 AM
SharkSkin
SharkSkin's Avatar
If the hood hits that, it will likely hit any 90° fitting you put on there. So, are the lower supports fixed or adjustable? I can't see mine with the belly pan on.
Quick Reply: all Aluminum radiator- 928 International
