Radar stealthing the 928
Below is my original question to him, and his response. I got a kick out of it, and well........this info could be useful to someone....
"Originally Posted by M21Sniper
Hmmmmm. I could really use a stealth treatment for my Porsche 928S.
Tell me more(about using a bra to reduce the RCS) Mr. Landgraff!"
Well, unless your car has air scoops in the sides to deflect Radar beams into the chamber never to bounce back out, a car bra will do you no good. The beams are readily reflected by the radiator grill, headlights and bumpers.
A Radar beam will Deflect away enough if the surface it strikes is more than 15 degrees off vertical. So a well sloped windshield with a plastic sheet glued ON FRONT will deflect beams up instead of through the glass and bouncing back out off the metal inside the car.
A typical car bra is made of a multi-layered rubber sheet that must be strapped tight to the metal of the car. OR it has to come with thin aluminum sheet already installed on the back side. Such RAM blankets were used by both US and British ships in the Gulf War as reported by Norman Friedman. He wrote an excellent book on the war but, in my estimation, gave out too much information --- at the time.
What happens is when a Radar beam hits a reflective surface, it oscillates for a micro-milli-teeny-tiny second before bouncing back to the receiver. Though the beam is not as narrow as a Laser beam, it is usually within a 30 degree cone thus allowing any surface angled more than 15 degrees to Deflect it out into the neighborhood.
In a RAM blanket or a RAM covering over metal, it's at that point of oscillation that disperses the Radar within the rubber material. 90 degree inside corners are the ideal Radar reflectors so both surfaces have to be covered. If the RAM is not attached to metal, then the beam goes through it, oscillates on the metal, and goes back out through the material.
The material itself? Well since we had to specify it on our drawings and they were not classified I guess I can tell you. Rubitex Type 3R. It's about a quarter of an inch thick and is a little stiff. We did use a much thinner material on handrail stanchions but it has to be glued in place and really was not as effective as the thicker stuff.
But as I said earlier, your radiator and headlights will still reflect a beam back at the Smokey. So the only use of the car bra has is it's "publicly" advertised use as a bug catcher.
Oh yeah. One more thing. A lot of Police agencies know about this and are changing over to Laser units to measure incoming or outgoing velocities. So, save your money unless your car is like Wonder Woman's Invisible Airplane."
http://www.worldaffairsboard.com/showthread.php?t=10381
Heh, ok, someone go buy a ton of that stuff and let's get to work!
If someone wanted to spend some time and money on this they could probably get pretty friggin' good results.
N-
N-
Hmmm, ok, i guess we need a radiator angling kit for our 928s.
Someone writing a list?
Hehehehe.
That part of the nose would have to be heavily coated in RAM or angled(preferably canting inward from top to bottom by at least 15 degrees as he states above). Same for the front marker/fog lights and T/S lenses.
The more i think of it, if someone really wanted to do this and spend the money, i think they could get some purty daggone good results. There is actually a heck of a lot of open source RCS data on the net, so it's not as if there's no guidelines to go by. The one area where i think you'd run into real problems with excessive returns is the wheelwheels and the rims.
Maybe we can talk to the guys that make Rejex and see if they can come up with a radar-absorbing variant.
"Hiding" from radar is more about reflecting the return waves away from the emmiter than absorbing or trapping them(ie, it doesnt really even matter if you 'bounce' a strong return, just as long as it's away from the radar source.
There's an F-117 pilot that posts on my board too.
The driving light lenses would be easy to cant downward and coat with polycarbonate, and i guess you could certainly cant the bumper downward behind the cover, though it would be a lot easier just to get rid of it.
I wish i was rich. I'm the kinda nutjob that would spend 20k on a project like this just to see if it actually worked, lol.
Now, if we could just get a scraping of that paint, we could get some more made.....
1) Mr.Landgraff's astute observation that more and more speed enforcement is done with laser.
If I were so inclined to be focusing time, energy, and money into stealthifiying cars, I would research ways to defeat the mighty laser.
2) If Smokey can see you, and his eyes don't agree with his speed detection equipement readout - you are in a world of trouble. Whether you're using a common detector or $20,000 worth of ultra-high-tech jammer-paint (LOL), you still have to slow down before the Enforcer can get a visual on you.
)Without the engine driven fan, there is plenty of room (on the 16V) for tilting the radiator. I have a spare hood, and I keep eyeing putting a rad outlet in it, along with an angled radiator. (I read that this is the best aerodynamic setup.)
