Blaupunkt Manhattan Question's
1988 928 S4....Can not figure out how to set the clock on the Blaupunkt Manhattan CD148. Also how to adjust the balance and fader. There is a Kenwood EQ installed between the Head and Amp, must not be stock, or is any of it stock? The unit sounds good sometimes, lousy most the time. I have researched many of the stereo threads but have run out on ideas to get this unit working good, or to just start w/new stereo. Have resoldered door speaker connections, and cleaned amp connections. What next? Any help appreciated.
Owns the Streets
Needs Camber
Needs Camber
Er, this is the only CD148 on the USA website.
http://www.blaupunktusa.com/Blaupunk...ch%20CD148.htm
Not sure what part of the world you're in.
There's a link on that page to a pdf manual.
Some of their manuals have more information than others.
Found the pin-out diagram for my Blau head unit there.
First Blaupunkt unit I had had a flakey volume control.
Ernest (NYC) German stereo in a West German car.
Thanks, the on-line manual got the clock set, now I will recheck all the connections per the diagram and hope that gets it working.
Any idea if that is the unit that came w/the car? What is stock in an 88? No audio info in my owners manual. Would that be a supplemental manual?
