New RA motor mounts..
Captain Obvious
Super User
Super User
Ask Eric B. from Shak-Attack. He did this on his 928 and has all the info on what size washers/shims to use. He brought some with him to last years Toronto 928 Fall Drive.
IIRC - it is recommended, but not "necessary".
I used shims when I did mine. (Sorry - can't recall the size - BUT - take one of the MM's with you to the hardware/fastener store, as you will also need different size nuts - your new MM's aren't metric)
As a matter of fact Eric B. supplied the nuts and I sourced the washers/shims . He used washers/shims , but was interested in what others have done.
Measure the height between the mounting surfaces. Mine were 76mm vs reported 78mm for new OEM mounts. I added 2mm thick flat washers, but as Mark said, it was likely not necessary.
My mount studs were standard M12x1.75 ( vs M12x1.5 OEM) .... some report the #2698 to have SAE threads.
Supercharged
Basic Sponsor
Garth S,
All the 2698 MM I have seen (there are lots) have been metric M12x1.75.
Roger
Roger
Captain Obvious
Super User
Super User
Originally Posted by watercooler
Imo000,
Do me a favor and post the time and date of this years Toronto meet.
The last few times I have been working.
Cheers,
Michael
Cheers,
Michael
I see you live in Caledon. I work for the Region of Peel (Brampton), maybe in the spring we can meet up. BIMMERMIKE from this board also lives in Hamilton and is itching to go for a drive.
Supercharged
Originally Posted by Imo000
Ok no problem. The winter meet has already happened back in January. The fall meet is usually not till Sept. or Oct. If there is a summer GTG I'll send you a message.
Originally Posted by Andrew Olson
......... The 401 makes it a pretty quick trip.
Captain Obvious
Super User
Super User
Not anymore.... the Canadian $$$ is almot at par! This is not really a good thing Last week I've seen a sign in a store "US Exchange rate 10%".
Supercharged
As for the local constabulary, of all the times I've driven to Toronto, I have only see one giving out tickets. Most of the traffic seems to flow at about 80-90 MPH.
Ok... no more hijacking.
