928 Forum 1978-1995
Sponsored by: 928 Specialists
TURBO kit VS. V8 engine swap
Old 02-19-2006, 08:32 AM
  #31
Fogey1
Fogey1's Avatar
Hybrids. Nobody's mentioned:
http://www.560sec.com/bulletinboard/viewforum.php?f=8
Old 02-19-2006, 12:37 PM
  #32
Jon B.
Jon B.'s Avatar
Originally Posted by MarkRobinson
These are not mustangs where you end up spending each paycheck on Shocks/Springs/Camber correction/Subframe Supports/Strut Bars/Control Arms/Swaybars/intake/heads/cam/lifters/springs/valves/injectors/spacers/throttle bodys/MAF/Cold Air induction/long-tube headers/off-road x-pipes/flowmaster exhaust/underdrive pulleys/chips/pumps/filters, etc.
If we were not pleased enough with the 928, we'd all be on other forums. After all, the 928 does not qualify in the golden performance rule: "Don't take a slow car & make it fast"
That is soooooooo true! The strong points of these cars FAR outweigh the weak points. Adding power isn't that big of a deal, and the only other things you might have to do to a nice well cared for 928 at the same time might be a few suspension tweaks and brakes! DONE!
Jon
Quick Reply: TURBO kit VS. V8 engine swap
