Clicking noise in rear of car.
Good day 928ers,
Got an 87 auto about a month ago with 95000 miles, really good buy, so there are a pretty good list of small things I need to fix but runs great, first time buyer and I am very happy, love the power and the feel of control in the car.
Issue that I wanted to ask today is about the rear of the car, when driving there is a clicking noise that gets faster as the mph's go up, of course hearing it goes away after about 35 as the tire noise takes over.
Could this be just the fact that when I got the car the carpet in the back was rotted so I tossed it, and the spare tire cover was toast too so I tossed it also, so there is no deadening at all back there now???
Thanks guys,
Dan
Thanks guys,
Dan
Heavy click ... light click ... click sensitive to left or right turn ... same in reverse ...etc????
You may start by safely jacking the rear and hand turning each wheel: also, turn each by the halfshaft ..... try to pinpoint the source.
If you start to think that it is a bearing, consider removing the halfshaft to decouple its contribution - then spin the wheel, for it will sit on its bearing alone.
If you back it onto ramps(so that the suspension is in it's normal position), set the brake and put the car in neutral you can wiggle the halfshafts around pretty easily to see if the clicking is coming from there.
BTW Garth, what you suggest would work on my car, but not an 87, IIRC. Aren't you forgetting about a very large nut? Or are you thinking of holding onto the halfshaft while you spin the wheel, hoping it won't whip around and take out some other nuts?
It is not childs play to remove; however, the thought was that if the bearing is suspect, the shaft must come out for its R&R anyway. With the shaft removed, the wheel/hub is fully decoupled from any contribution from the shaft, differential, .. so by then spinning the wheel, one gains a better view of the bearings health. The same applies to the CVs, once the shaft is removed..
The 32mm nut yields quite well to an air wrench, and is far easier than the handful of allan bolts on the inner CV.
Light click, and there is no feel to it, does not sound like a wheel bearing, not a rubbing or grinding, just a light click....I was thinking it might be the rear end. Only really hear it while going forward, turning does not change anything.
So it is not normal, even without carpet or anything in back.....there is no light click to the rear end normally?
Originally Posted by nhporsche87
Good day 928ers,
Thanks guys,
Dan
Thanks guys,
Dan
You can do all that, but it is much easier to just check for tears in the boots. I've never seen a CV joint just go 'bad' with an intact boot in place. Normally, the boot rips, the grease escapes(which actually takes quite a long time), and then you get clicking.
So, if you get under there and have a ripped boot, it's the CV joint. Just re-grease, re-boot, and go.
Good idea -- unless the PO had fresh boots put on a flakey CV joint... as I alluded to in my last comment. If it's clicking, fresh grease will only hide the problem temporarily while it gets worse....
I had another guy that decided he didn't need new boots(cant remember the model, but it was some jap car that called for like 6 hours to change the boots- expensive job), and he insisted that i just 'duct tape' the boots back together. Being the accomodating fella that i am, i charged him $30 bucks and duct taped the hell out of it for him....believe it or not, the thing didn't leak anymore after that for almost two years!
LOL....people are nuts.
Thank you guys for the info, when i get a chance I will take a look at the boots.
Obviously as stated before in this forum, best money can buy for advice from people who do it and can share the knowledge, awesome.
I didn't think you could pull the stub axle out without having the inner CV off??
"consider removing the halfshaft to decouple its contribution " unquote. .... 'removing' being the key
