Help! Clogged Fuel Filter Symptoms
Originally Posted by Steve 88
Jerome, I have an extra old-but-functional MAF you can use for a test. I live near the Nova campus - can't be very far from you.
Thanx... and have a good time with the gang Saturday, if you make it.
I pulled the MAF on Sunday. The car started and ran for about a minute. When I tried to feed it a little fuel it quit and would not restart. I will reinstall the MAF and see if wiggling the plug changes anything. Does anybody have any suggestions where I should look next?
Thanx,
Jerome
Thanx,
Jerome
Alight im in need of some guidance. The last year's project had involved a built engine block I purchased off of another member. The head was attached and a new super 61 was fitted as well. The car sat for 3 years after a blown headgasket and it had about a 1/2 tank of e85 and premium blended in it. I filed it up with premium and added c foam and Heet water remover. No improvement though, fuel filter looks stock and in the process of changing. I replaced the plugs, wires aren't old in use but have a few frayed points in the outer covering so I'm ordering new ones.
Could the filter cause the car not to accelerate? Many times it won't even idle until letting it sit and try again then it will idle but any attempt to give it gas it backfires and stalls.
Help appreciated
Help appreciated
Help appreciated
Help appreciated
What year/model 928? (or are you talking about a 951?). If its a 928, a range of factors could cause that behaviour, depending on which injection system it has (CIS/K-Jet, L-jet, LH-jet 2.2, LH-jet 2.3?)
THe fuel filter is easy to remove on a 928 - the actual filter, not just the tank strainer as shown in the posts above.
Start a new thread about your car, as people are going to read this and start replying to posts from 2006, instead of noticing that yours is the only new one in here.
Help appreciated
Help appreciated
So its a 951 - I figured it was given your posting history.
You've necro-posted this 10 year old thread in the 928 forum.
You'll find people more familiar with the 944 here:
https://rennlist.com/forums/924-931-...-968-forum-70/
