Upper ball joint boot split on an S4.
Is it possible to just replace the boot on the upper ball joint on an S4? The joint feels solid, but there is grease coming out of the side of the boot. I've searched through the forum and have found that the ball joint can't be replaced without the whole arm, and also that the lower boot can be replaced, but I can't find anything on the upper boot.
TIA!
TIA!
Here's an example of a proper ball joint seperator tool. It saves you from mashing the aluminum on the control arm if you are using pickle forks.
Heres a link to the website I bought mine from Ball Joint Lifter
Good luck!
![](http://forums.rennlist.com/upload/pict0025a.jpg)
Good luck!
