CIS to EFI conversion
Originally Posted by Lance J
no my non-ic'd boost max will be 8psi. i'm thinkning of using a slightly thicker headgasket. the is300 turbo guys use them to lower there compression down to 9.0:1. and they boost to about 18 psi. i'm not gonna reach 18psi maybe 14psi w/race gas.
Administrator - "Tyson"
Originally Posted by BrendanC
Hacker - did Todd buy the blocks to sleeve?
Originally Posted by Hacker-Pschorr
I'm not sure how many engines he has lying around anymore. Last time I was there he had a block all prepped for the sleeve’s he made, and picked up a basket case of an S4 as a donor car. I’m sure there will be a 7.1 liter SC S4 running around Wisconsin in no time.
Originally Posted by Jim Nowak
I've got an Electromotive Tec-II on my 5.4L 2-valve engine but tuning it to run properly under all conditions has been a major pain.
Call fred. He can explain the differences.
Once you drive your car at 8psi, I think you will find that is enough. I ran mine at 12 psi for a couple of days, but i did not have froged pistons so I backed off.
Its fast enough at 8 but 12 is sick.
I ran into some guys down here that had built a S4 with a bored out custom motor at around 20-24 psi and they were making over 900 hp. Could not keep the drivetrain together though.
i'd be happy with 8psi but to have 12psi under you thumb is a great feeling.
so let me get this get all the 81 l-jet parts but not the fuel rails
get those from a 85 lh-jet. that way i can use ford injectors
Ok, here are a couple links to converting (starting from L-junk) to the GM ecu setup.
First one is the conversion on a 928, 2nd one is more about using it in a boosted setup.
conversion to GM ecu
Modifying the GM ecu
Holy cow, that's quite an interesting little modification you've got there. Nice belt-snail, too.
If you don't mind running high fuel pressures, you could run the stock L-jet or 16V LH-jet fuel setup. The problem is that you have basicly no options for higher flow injectors if you want to run normal fuel pressures. Also, the 16V LH-jet S2 injectors aren't plentiful used or cheap new if you get a bad one.
I've been thinking about this Matt. What about drilling the holes out in the LH 16V intakes to accept the later injectors? Drilling it out a bit to sink it lower towards the valve?
