Power steering fluid reservoir removal (1980 5 speed)
Anyone know if the mounting bolts here screw into the frame or do they have a nut in back of them that requires accessing the nut from the inner wheel well?
I loosened one of the two and it didn't catch/screw back in.
One thought is perhaps there was a nut on the back of the bolt that fell thru to the inner wheel well?
I can't remember whether the nuts are forwards or aft of the splash shield. It will be self-evident when you look in there, either there will be two (well, now 1 on your car) nuts visible about 15 mm apart, if they're aft or the splash shield, or there won't. Apologies for all the commas in that last sentence.
