Rattle / Tick on Deceleration Need suggestions
I have a strange rattle that started about 1 month prior to parking for the winter. When I rev the car, then let off the gas, it sounds something like a ticking that slows down slower than the engine rpm. It seems to rev up with the engine but then slows down slower than the engine.
Any advice would be appreciated.
Thanks,
Thanks,
Team Owner
check the clamping boolts on the drive shaft look carefully for a orange colored dust surrounding the coupler if you see this then the bolt is loose and the shafts have worn, also I see you have a 5 speedyou may have signs of the throwout bearing going bad as the lubricant is drying out of it try putting some engine oil in the TOB , and last look at all of the exhaust shields front to back for mounting tightness, Stan
