OEM Quality Clear turn signal lenses now for all 928 models
Originally Posted by Gretch
Now if we could just get clears for those fender mounted lights......
Give Mark Anderson a call , 928intl i think has them.
IRRC they require some cutting as the orange side marker lense is glued to the bulb housing behind it. Your cut the orange one off and add the clear on in its place. There was a write up on here about it somewhere.
That would be the same deal as Joachim's Euro side-marker lenses.
I used a Dremmel cutting wheel and was careful to only cut into orange material. A bit of sanding after the initial cutting got me down to the reflector material. The plastic was not succeptible to any of the plastic solvent-type glues that I tried so I ended up using one of the "Goo" products, which is actually a glue, rather than a solvent.
Cottage Industry Sponsor
I already have the clear Euro side marker lenses for those who own Euro sharks.
Thanks, everybody, for lookig and for the orders!
We do have them and here is a picture.
http://928sg.com/cosmetic.htm
Supercharged
Originally Posted by BrendanC
That means if you can do the fronts, sides, and... well, all we need is something for the rear.
Originally Posted by Andrew Olson
Tony did the Testors Paint mod to his rear lights. I wonder how they're holding up? Tony?
Funny i just washed the car today and stood back and looked at it...makes a marked difference in the appearance of the car. Just like the clears do up front.
