928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine build problem, pulled threads
Old 12-30-2005, 07:11 PM
Ole
Ole's Avatar
Carl, Does ARP also make main studs (12mm) for the 32 valve?
Old 12-30-2005, 07:28 PM
928SS
Road Warrior
928SS's Avatar
how about timecerts for the block threads?? seems a few builders like them
Old 12-31-2005, 12:01 AM
Carl Fausett
Developer
Carl Fausett's Avatar
Not directly for this application. But, I measure the studs and send them in and we try to cross them to another application that has the same size. Sometimes I get lucky.
I won't know until Tuesday or Wednesday.
Old 12-31-2005, 08:22 AM
John Veninger
John Veninger's Avatar
Came across this today looking for something else.
Old 12-31-2005, 10:04 AM
GlenL
GlenL's Avatar
John,
Very true. But I thought Porsche had recinded that directive. (No?) Anways, doesn't everyone Loc-tite those nuts? I do. That should seal it.
Old 12-31-2005, 10:17 AM
John Veninger
Maybe, do you know the publication were they changed back?
Old 12-31-2005, 10:42 AM
GlenL
GlenL's Avatar
Nope. No publication forthcoming.
What is coming back to me is the smooth tones of Mr. Jim suggesting that those special nuts weren't worth the extra money if I sealed them. What's his P/N again?
A check in the PET shows the "928" series nuts being used throughout the series for the 12M studs. Ordinary nuts are in the "N" series. Lemme change that: not recinded, just not necessary.
I've got to wonder if this wasn't an attempt to keep a bit more oil and pressure going to the crank. Having coated nuts would be easier for manufacturing than gooping them one-at-a-time.
Old 12-31-2005, 11:11 AM
John Veninger
Wonder if some very light 571 or 518 would be in order?
Old 12-31-2005, 11:27 AM
Herr-Kuhn
Herr-Kuhn's Avatar
Time sert is a great insert, much better then a heli-coil assuming you have the beef to do it.
Getting the studs out of the block (especially head studs) is not easy. It took two very strong men to remove the head stufs out of the Goldmember's block. The trick is heating the block locally where the studs are threaded in. Even then it can be brutal to get them out. 20+ years in one spot=stubborn!
There is a guy in Florida selling larger studs for the 928/944 and this requires machine work to the block.
Old 12-31-2005, 01:12 PM
Ole
Ole's Avatar
For a discussion on last resort use of time-sert repair http://forums.pelicanparts.com/showt...highlight=time
Quick Reply: Engine build problem, pulled threads
