Thicker Head Gasket (Cometic)
Rennlisters,
As I have mentioned before my S/C set up is currently limited to about 5 PSI.
The 10.5 CR is something not to be taken lightly for longevity
So we were asking about the thicker Cometic Head Gasket and if anyone here had any experience with it?
Also has anyone used the thicker Porsche Head gasket and to what effect?
Thanks,
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Thanks,
Captain Obvious
Super User
Super User
If you have the heads off might as well go with a set of low compression froged pistons, they are the best way to go to lowering the CR. They are alot stronger than the stock cast units and with them you can turn up the boost to at least 10psi. The thicker gasket is some what of a band-aid solution.
Edit: So, where do we find some of those froggy pistons?
I don't think using a thicker gasket to decrease CR is a good idea.
928 Quench/Squish Sensitivity
as most of you may know (and I recently discovered), increasing head gasket thickness or increasing deck clearance on a quench designed motor can actually lead to increased detonation...some motor builders claim anything over .060" total squish (gasket & deck clearence) can SEVERELY INCREASE detonation....http://www.speedomotive.com/Building%20Tips.htm
potentially bad news for the stroker crowd trying to lower compression for a bit of extra FI HP...
this only leaves reducing the stroke/volume while keeping the same compresson ht or using a much larger dish (50cc) to lower compression for FI motors starting out at 10+:1 compression (strokers etc)....so much for just "slapping in" a lower compression ht piston....yep, even the angles count....
anyone know what the total squish/deck clearance limits are for the 928 or if it is squish sensitive?
as always, thx for any and all of your squishy/sensitive comments...
85Shark AT/Platinum
(updated 11/07/05)
85Shark AT/Platinum
(updated 11/07/05)
We have used Cometic head gaskets with good results, no detonation on 10psi of boost. Using a .074 thick head gasket will drop compression by approx. 1/2 a point. There are tricks to making them seal though, contact us for a full explanation if you are interested.
When my heads were off this spring, I went with the thicker Cometic gaskets. IIRC, they were 2x the thickness of the regular gaskets--but they make a size or two even thicker than what I have on. I chose the thickest they warranted to still have the same clamping force as the standard one--any thicker, and they don't warranty the clamping force, because there's an additional layer.
I spent some time talking to one of the techs from Cometic as I was trying to determine the thickness I wanted. His ballpark estimate was that the CR would be reduced by about half a point, although I don't think that's terribly scientific.
I also figured this might be some additional protection against bending valves if I experienced TBF (again), but this too is very unscientific and probably incorrect. How far do the valves open when they open?
You should expect some weeping of the gaskets after they're installed for a couple heat cycles. This seems to be common. I don't have any problems with leaks.
I will say, however, that I think the car feels noticably slower, although I have not ever dynoed the car. One of these days I should probably do it... My digital boost gauge reads 9lbs of boost right now, but it only displays in whole numbers, so I'm not sure at what point it rounds up. Andy and I think conventional wisdom says it should make somewhere around 8 with the pulley I have on now.
Lastly, I will also point out that I used to have some tip-in knocking if I floored it from a stop. That problem completely went away with the thicker gasket.
I realize this conflicts with an earlier post re: quench/squish, but I'm just sharing my seat-of-the-pants real life experience.
Hard to believe that Cometic would last as long as they have and offer so many different kinds of thicker gaskets if this was such a no no. But I'm not an engineer.
Brian - I think with the thickness you used, with was the 8x one Ithink, you went down more then half a point.
Turn up that boost!
Turn up that boost!
To clarify, I think I used the 0.071 or 0.074 instead of the 0.045 that Cometic lists as stock.
Brendan, I'm not quite sure what you said, but I think I get the point. I have smaller pullies that I will install at some point. I need to get the car dynoed to establish some sort of a baseline with my current setup vs. what most other TS guys are getting, and then see whether any of the tradeoffs between higher performance and reduced longevity are still appealing.
How about head bolts? Is there any reason to try something like ARP?
This all came about because the TB/WP needs to be done, and we figure we can make things "better" by throwing in thicker gaskets while-we're-in-there. Are there any other upgrades that help reliability and longevity?
Used stock pistons would certainly be cheaper than new aftermarket. How close are GTS piston dimensions to S3, S4, or M28-45/46 pistons? Would a piston swap to readily available (or not as readily available M28-45/46) pistons be feasible?
Captain Obvious
Super User
Super User
