Accusump placement
Hi,
I bought an Accusump kit to my street/track car (90 GT). Does anyone have any recommendations where to put the accusump? The car has most of the interior intact, I was thinking about putting it in the luggage compartment behind the left rear seat.
Regards
/Rehan
Regards
/Rehan
I welded in the accusump mounts on the rear crossmember (this x-member is the back of the rear seats) behind the driver's seat. My lines will go across the tranny tunnel and down through the grommet where the tranny tunnel and bulkhead meet. You can see the straps in these two pictures located behind the driver.
I put my Accusump behind the passenger seat. I figured that was a good position for balance to offset the normal "no passenger but driver" loading on the track.
I wrote a white paper on the installation - send a note to info@electronikrepair.com if you'd like ot see it.
Administrator - "Tyson"
Who needs a heater?
![](https://members.rennlist.com/pageauto/engine8.jpg)
Thanks guys, I'll think I'll go with something like John V placement or the spare tire well.
I also need to check how much space I have in the right fender well, it might fit there as I'm going to delete the washer tank.
I mounted mine behind the front bumper.
See the link:
https://rennlist.com/forums/showthre...24#post1620524
Cheerio,
P
See the link:
Cheerio,
P
Originally Posted by Jim_H
It fits great behind the rear bumper
https://rennlist.com/forums/attachme...id=92497&stc=1
https://rennlist.com/forums/attachme...id=92494&stc=1
https://rennlist.com/forums/attachme...id=92495&stc=1
Ok, I like the rear bumper best, add the weight at the rear and pretty low, which is nice.
Louis, I noticed that you have a switch mounted on the electric valve, why? Is it just as an extra security thing that you might want to turn it off for some reason?
Thanks for the quick response!
/Rehan
/Rehan
Louie did an outstanding job running the lines and mounting his accusump inside the bumper. He has a knack for finding great places to place his equipment...
He's probably not ready to show off his oil cooler placement yet...
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
/Rehan
/Rehan
I have a lot more pics of the install and oil line routing if you, or anyone else, is interested.
I'll have an switch in the driving compartment to turn the accusump on when going to the track. Normal driving I'll just keep it shut off.
