Rough Cold Idle After O2 Sensor Replacement??
1984 928s w/ 5 speed
If you put a new sensor on a x-y plotting meter, some take a while to begin generating output, others swing wildly until the voltage output begins to move in a slow sine wave form, assuming the fuel injection is OK. You may see some initial variance due to this, which disappears in 30 min running time. edit ... this is a first time thing only with an out of the box sensor.
The Bosch unit mentioned should pose no problem .... any 3-wire sensor of that generation will do the job.
The heater should heat to operating temp in under 30 seconds and polarity on the white wires does not matter. The variance Garth mentioned should disappear in under 2 minutes or whenever the engine reaches operating temp. With an an heated sensor it could take longer.
Was the old sensor rusted in place? 3-wire sensors ground the sensor to the exhaust. If the threads were rusted or you used non-conductive sealant/antiseize the sensor will not ground properly resulting in a bad signal.
Jeff, it is deff. wandering a little. The plugs, wires, rotor, and cap were all replaced a couple of weeks prior to the O2 so I feel confident in ruling them out. As far as vacume lines, I didn't have my hands anywhere near any vacume lines during that maintenance. But I will try to check for that just in case. As far as idle being open loop. Are you reffering to the micro switch on the low side of the throttle? If so, mine doesn't work and didn't work prior to the O2 sensor. According to another thread here on Rennlist, adjusting so that micro switch is innoperative is actually supposed to be a positive performance enhancement. I'll try to locate that thread. I think it was M. Kibort who brought it up in a discussion about L-Jet troubleshooting.
Flying Dog, I didn't use any sealant on the sensor and the anti-sieze was already on the sensor when it came to me. I would assume it would be OK. There wasn't that much of it anywway.
Oh yeah. One more thing. I also noticed that the idle speed is 200 RPM higher upon startup/ warm-up. It used to be 1000 an dnow it is 1200. I was planning on adjusting it down to where it is supposed to be but wanted to do that after the O2 install, just in case it was causing it. I guess it wsn't. The WS manuals say that a O2 sensing tool is required to set the idle adjustment properly. Is this really necessary?
1984 928s 5-speed
IMHO, it is a good idea to have the idle micro switch on the throttle body (TB) functional - without it, what do you have for engine braking? It reduces fuel at idle, and if it is not functioning, it may contribute to a strange idle: what was your initial problem ??
It can't hurt to reduce the idle by turning the huge sloted set screw (~1/2" head) on the right of the TB - which controls bypass air around the throttle plate for idle. When that is in the ball park, the CO adjust is actually the 3mm allan key head on the lower left of the AFM when facing the engine ( you need a 10-12" extension to reach it). It gets to be a long story how to adjust it, but this was previously posted: in short, it can be set much like a carburator mixture screw, but it controls unmetered bypass air around the vane that measures total air flow ... as few of us have CO sensors ( unless you care to hook a multimeter up to that new Bosch sensor - which does the same thing).
