SC install with links to pics
Rennlist Sponsor
Rick,
>If I'd known your kit was coming I'd have waited.
Boost is boost... and BOOST IS FUN, no matter where you get it!!
I am truly happy for you and know you will be having lots of fun.. just promise me you will consider making me your exclusive tire supplier so I can retire early :-)
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Dave, does it NOT matter which direction the air flows through the throttle body?
No vacuum port issues?
Rennlist Sponsor
Brian,
>Dave, does not NOT matter which direction the air flows through the throttle body?
Correct, it doesn't really care.
The originals are no longer "vacuum ports" and typically capped as in the photo, OR you could make one of them larger for your Idle Control Valve "input". You do have to make new vacuum ports on the other side of the throttle body "plate".. No biggie.
Originally Posted by Rick Carter
85 32v modified
http://www.lasotaracing.com/carter/5.jpg
As far as the motor goes...
To simplify things we modified the kit to run a single 6 rib belt. We made a hub-centric spacer to bring the power steering pulley out to line up with the alternator and then machined a spacer to hold and idler pulley between the alternator and power steering pump. The alternator tensioner controls the tension on this belt, to remove it you just loosen the tensioner on the alternator.
Thanks!
Rob LaSota
Thanks!
Rob LaSota
I have built the power-steering pulley spacer 320mm. This lines up the forward-most groove with the forward-most groove of the alternator.
The power-steering pulley has 5 grooves, while the alternator pulley has 6 grooves. What belt did you use?
Also.... what idler pulley did you use on the alternator pivot bolt?
Thanks!
Getting dangerously close!!
Under the Lift
So, the power steering pulley is up to this amount of tension? I understand the alternator is, but I wasn't sure about the power steering.
this drive belt solution is a really good idea...
nick.
nick.
So, the power steering pulley is up to this amont of tension? I understand the alternator is, but I wasn't sure about the power steering.
Bill
Bill
Does this answer your question?
We had to relocate the power steering reservoir, which now mounts to the 3.5" inlet piping. The kit was originally designed to run 2 separate belts for the power steering and alternator. To simplify things we modified the kit to run a single 6 rib belt. We made a hub-centric spacer to bring the power steering pulley out to line up with the alternator and then machined a spacer to hold and idler pulley between the alternator and power steering pump. The alternator tensioner controls the tension on this belt, to remove it you just loosen the tensioner on the alternator. We also had to machine the lower pulley to mount to the crank pulley correctly as well as machine a spacer to bring the blower pulley out 1/8" to line up with the lower pulley correctly. Tension should be checked every 3,000 miles or so on the blower belt, the tensioner for it is off the front blower bracket
Hey Rick,
That is an awesome looking job. Every time I see a clean SC install, I drool. One suggestion if I may, get some new hose clamps for the rad in/out. I'd hate to see one of those rusted clamps give up the ghost and take out an automotive work of art.
Cheers and have fun with the pumped ride,
John Fagerlund
'89GT
John Fagerlund
'89GT
John Fagerlund
'89GT
John Fagerlund
'89GT
Although DR has already done it, heres an idea for Ver2.0.
it would look really sharp!!!
I dont think you car is compatible with a shark tuner though?
We're working on that :-)
