Baseline Dyno Diagnostic Help Please
#32
That was one of the things that I was going to check when I do the SC install. Last spring when I did the timing belt and water pump I noticed that the cam on the passenger side was about 1/2 tooth off from the crank and the driver side. I am going to take the valve covers off to paint and check TDC at the same time. I wanted to buy one of those tools from PorKen but he was sold out. I would love to borrow it along with your timing belt tension tool in January if I may. Hopefully we will both be at the meeting on the 12th.
