3rd Brakelight Installation Advice
Originally Posted by SharkSkin
Whenever I'm behind a shark with the 3rd light, it seems to me that the light obscures a lot of their rearward view...
Originally Posted by glack
You know, I'm starting to share this view too (no pun intended). I would really like to install an LED strip akin to what the 993's were running, but I suspect that making a custom install that looks clean enough would be a ton of work - any ideas?
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Jim Mayzurk
93 GTS 5-spd
Why not use the wire already in the harness for this? You're going to get brakelight warnings if you unbalance the system by adding a light to one side.
I think there is room inside the hatch if you care to cut into it. Also I think you could buy one of the strip-of-led products like folks have been using for their gauge illumination and make something thin that would sit unobtrusively just aft of the headliner section on the hatch. I like that idea better, no cutting.
![](http://jacquemond.com/928rs4.jpg)
Somebody was selling a fiberglass GTS spolier copy with an LED third light on ebay a while ago.
Can you identify where in this picture the wire you are referring to might be?
Electron Wrangler
Glack,
You will need to pull the wires to the hatch as Dave says - how will you work around the bulb monitor issue? On my GTS the high stop lamp is just in parallel to the Right stop lamp...? try that first...
Another option is to use an additional relay to drive the new brake light with its coil connections coming from the right brake light feed.... the coil only takes <200mA - so probably within the tolerance of the brake light current monitoring... if not feed it directly from the stop light switch before it goes to the bulb monitor.
You'd want the relay fed from an X-Bus or 30 Bus (always on 12v bus) supply so the brake lights will always operate together (they use X-Bus). You could probably do this at the back of the car or at the Central Electric panel.
Alan
Alan
