Fuel Press Reg 84 vs 87?
928 Collector
Are there differences? I cannot see physical differences, but of course part numbers differ and Int'l list 80-86 and 87 separately.
Rennlist Sponsor
Different pressures.
As you said physically the same.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
928 Collector
Damn Matt that is wonderful of you.
... I have inadvertently had an '84 unit crimped into my nice shiny new S4 fuel lines. So I guess I'm going to visit the hose shop soon again
I think it would be an option, but you might want to get a more experienced opinion. S2s, S3s and S4s are all around the same HP. S2s and S3s run 24lb and the lower pressure regulator. S4s run 19lb and the higher pressure regulator. You could run some of the Ford 4 nozzle injectors. That's my plan once I get S3 rails installed.
I need an earlier unit for my S4 project. Andy spec's the 24 lb injectors/ early regulator with is Autorotor kit.
You guys have a spare one kicking around?
The older unit is lower pressure (30-36psi IIRC) for use with 24lb injectors. The newer unit is higher pressure (47-55psi) for use with 19lb injectors.
Brian, I don't have one now but may next week.
keep in mind that the two regulators are used with the up to 50psi system (adjusted up with the adjustable regulator) and only one is used with the single regulator system on the s4 and the pressure is close to the same. to make things more complicated, the fuel pump pressure , i think, is greater at the source.
mk
mk
