928 Forum 1978-1995
Sponsored by: 928 Specialists
MAF Question/Voltage
Old Nov 23, 2005 | 07:14 PM
Shark_gts's Avatar
Shark_gts
Default MAF Question/Voltage
I hooked up the "bad" MAF that we took out of a 90S4 only 70K km's on the test bench.
I ran a couple of burn off cycles with it and it now is responsive to flow and seems to work fine but.... the zero flow voltage is a little low - 1.55 volts v.s. 1.67ish for a known good unit. Manual states it should be ~ 1.6 volts
The adjustment screw is available (Japan unit) and when turned doesn't seem to change a thing.
The adjuster screw on the other MAF (North America) we have is plugged/not available.
Paul Jager
www.jageng.com
Old Nov 23, 2005 | 07:18 PM
the flyin' scotsman's Avatar
the flyin' scotsman
Paul.................check out John Speakes web site for all pertinent info re. MAFs.
I do believe the adjuster screw is plugged at the factory after a specific model year they're non adjustable
Old Nov 23, 2005 | 09:09 PM
Garth S's Avatar
Garth S
IIRC, this adjustable pot is used as an idle mixture control on the '85-'86 32v - and is not used in the '87+ 32v ... neutered ....
Old Nov 23, 2005 | 09:11 PM
the flyin' scotsman
neutered................sounds very painfull!
Old Nov 23, 2005 | 10:27 PM
Shark_gts's Avatar
Shark_gts
The allen head driven arm is tied to an adjustable pot on the circuit board. It did nothing for the base voltage, but a bit hard to check for the voltage at flow. I suppose I could hook up the central vac to it.
Old Nov 24, 2005 | 01:59 AM
Louie928's Avatar
Louie928
Changing the pot won't change the MAF output voltage. One end of the pot connects to ground inside the MAF. The other end of the pot comes out of the MAF on pin 6. On '85/'86 cars, pin 6 connects to the LH on pin 14 and affects the idle mixture. MAF pin 6 doesn't connect to anything on '87 and later 928s.
Old Nov 24, 2005 | 06:06 AM
John Speake's Avatar
John Speake
Hi Paul,
The zero flow figure is only a very crude check that the MAF is working at all. It is not an accurate measure of whether the MAF is any way near calibration.
You are looking for errors of less trhan 1% at known airflow rates across the MAF operating range to be able to determine whether it is "good" or not The no airflow figure is useless for that purpose.
Louis has given you the answer on the pot. You can't adjust the pot to bring a bad MAF into calibration. The pot can help the LH to compensate for an aged MAF, but the adjustment is only useful at idle. This applies only to pre 87 non-cat cars, running open loop.
Regards
