Couple "new timing belt" questions.
Originally Posted by Flint
I don't see how I can put the tensioner arm on first since the belt has to go behind it. There isn't enough slack with it in the way either.
Well, looks like it worked. I don't understand why the driver's cam won't line up, however. So I put both cams off the same amount and I'm hoping when I put tension on, it'll pull things into line.
Originally Posted by mulik51
I just put mine on. The driver's side is exactly on the mark and the passenger side is about 1/3 tooth moved. I assumed it was OK....
Klim
Klim
Mine were 1/4 or 1/3 tooth off but I forget which way. I have Porken's adjustable cam sprocket kit now so I can't check.
Advanced would be the mark forward in it's direction of travel toward the WP and driver's cam. So if you're standing in front of the car with the crank and driver's cam lined up, the passenger's cam sprocket mark would be to the right of it's indicator.
Make sure you monitor the belt tension the first time you hand turn it over. It will push all the slack back to the tensioner and passenger cam which can jump a few teeth.
Thanks for the answer. I will sleep well now
I don't know very well where is advance and where is retardation, but the mark on the spocket is about 1/3 tooth to the left of the mark on the cam housing. I thought it would be allright![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Klim
Klim
Two words: DIDN'T CLICK!
