Air pump squeek
Last winter's project was to r/r the air pump. A re-built one was installed. It felt rather "tight" when I turned to by hand before installation. The supplier said it would take 500 miles or so to fully break in, probably got 600 on it now. From examining the old one, I would describe the material on the fins that contacts the wall of the pump as graphite. I'm thinking of shooting some WD40 past the filter in through the intake to the pump. Anybody have suggestions? It's just an irritating noise at this point, but it is getting worse. If that doesn't work, the belt comes off after the next inspection. TIA.
DO NOT put oil in there. You might be able to exchange it at this point, but if you put oil in there it will kill the blades. Also, did you inspect/test your diverter valve and check valve? A bad check valve will allow exhaust to flow back into the air pump, also likely to kill the pump.
The graphite will have a petroleum or alcohol based carrier. Not a good idea either, IMHO. I'd say drive it back to where you got the pump, drag the counter guy out there, open the hood, start the motor, point and say, "WTF???"
What Dave A. (Sharkskin) said. I helped a friend put a rebuilt air pump on his 89. The pump was completly silent after the install. You got a defective unit or a bad re-build. Take it back!
Jim Mayzurk
93 GTS 5-spd
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Jim Mayzurk
93 GTS 5-spd
Originally Posted by Jim M.
Take it back!
Jim Mayzurk
93 GTS 5-spd
Jim Mayzurk
93 GTS 5-spd
