928 Forum 1978-1995
Sponsored by: 928 Specialists
Another headlight problem
Old Jul 13, 2007 | 06:09 AM
CaseyH's Avatar
CaseyH
You did what!?!?
Old Jul 13, 2007 | 09:51 AM
drnick's Avatar
drnick
its a track car so weight loss is important, the motor for the lights is really heavy!!
Old Jul 13, 2007 | 12:33 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Sorry but I don't know the ansewer for this one but Porken might!
Old Jul 14, 2007 | 07:08 AM
drnick's Avatar
drnick
porken or anyone else??
Old Jul 19, 2007 | 01:22 PM
PorKen's Avatar
PorKen
Inventor
Nick,
I removed the headlight relay, so I had to bridge 3 or 4 terminals. I used two of the headlight motor wires to trigger relays mounted in place of the motor, not the regular headlight wires, so this may not help you.
Old Jul 19, 2007 | 01:48 PM
Alan's Avatar
Alan
Electron Wrangler
Bridge the terminals that normally tell the relay the pods are up... what year is this on - the relays work differently <87 & 87+. I assume yours is the early type..?
In that case you will need to bridge 86M & 56 on the relay...
circuit 56 is lighting in headlight position.. in this config you don't need a diode.
If your plug to the motor is still there connect (or splice) the 56 & 86 terminals (White/Black & Green/Yellow wires).
BTW to others - don't do this with the motor connected!!
Alan
Old Jul 19, 2007 | 06:42 PM
drnick's Avatar
drnick
Default pics
ive managed to attach some pics of the new headlights and surrounds. ive borrowed from porkens ideas using the hella 50mm halogen projecor and a similar bracket. i found a guy who made up the surround in fibreglass for me.
alan, the car is an 86, i will try as you suggest and report back.
Old Jul 19, 2007 | 06:54 PM
Alan's Avatar
Alan
Electron Wrangler
Nick - I like the front end (preferrably without the plate - but I know you have no choice)... is that the Jaquemond version?
The lights look funky! just like little eyes looking at you... good job on those surrounds and nice job on the overall effect... that is one interesting color - pearlescent?
Alan
Old Jul 19, 2007 | 07:17 PM
JHowell37's Avatar
JHowell37
Another place for headlight malfunctions to occur is the combination switch with the hi-lo selector. When I first got mine when I would switch from low to high, one of the headlights would go out. Since the car is disassembled I took the switch and blew some compressed air through it and worked the lever back and forth countless times. It seems to be working now.
Old Jul 20, 2007 | 01:50 AM
drnick's Avatar
drnick
alan, its a lamborghini orange with metalic and i think the front end is a nock off of the original strosek stuff which i got from some guys here in the uk. im really pleased wih the way the headlights turned out
Old Jul 20, 2007 | 03:15 AM
CaseyH's Avatar
CaseyH
NO EXCUSE!
Old Jul 20, 2007 | 08:14 AM
drnick's Avatar
drnick
casey, although i like the popups i actualy quite like these replacements as well. i think they really suit the car, i have no regrets!!
Old Jul 21, 2007 | 05:40 PM
drnick's Avatar
drnick
so now i have a different problem.. now the driving lights come on with high beam but the dipped beam goes out! any advice?
