Throttle Cable Pulley Bearing
The throttle cable pulley marked C in the picture has a bearing in the centre. Can this be replaced easily, and if so does anyone know the bearing number?
I don't know, but a word to the wise:
The connector to the crank angle sensor is right under where you're working and gets VERY brittle. If you move it or put pressure on it it may crack.
