928 Forum 1978-1995
Sponsored by: 928 Specialists
Ride Height, how low can I go in the front?
Old 11-05-2005, 12:57 PM
Ed Scherer
Ed Scherer's Avatar
Old 11-05-2005, 01:26 PM
GlenL
GlenL's Avatar
Thanks, Ed.
For the number of times this comes up, should get a sticky or something!
Old 11-05-2005, 02:49 PM
UKKid35
UKKid35's Avatar
After fitting my newish Bilsteins my front must be about 200+, I've just ordered a Hook Wrench to adjust it back to spec. I made sure it was high because when I previously fitted Koni's it ended up around 140 - 150, and was bottoming out continously on London's speed bump and pot-holed roads, that was scary.
Old 11-06-2005, 08:31 PM
BIMMERMIKE
BIMMERMIKE's Avatar
Thanks, are cd WSM good? I see ebay has for $24.99
martin D
martin D's Avatar
Originally Posted by UKKid35
................I've just ordered a Hook Wrench to adjust it back to spec.
....................... when I previously fitted Koni's it ended up around 140 - 150, and was bottoming out continously on London's speed bump and pot-holed roads, that was scary.
You should have asked ,I've got one you could borrow. no luck with the other tool yet Im afraid though.
Yerrr.. wimp Paul , mines 125 mm all round & has negotiated London's roads on loads of occasions, even with 2 passengers, remember
Old 11-06-2005, 08:36 PM
JPTL
JPTL's Avatar
I'm at about 165 front; 160 rear w/Bilstein/Eibachs now, and I'll never go back.
I was lower all the way around.....too low. Somewhere under 150 in the front. I had a good alignment done after the lowboy ride height, and didn't get any weird handling or uneven tire wear. It looked good, but it was no fun to drive. I had to slow to a crawl for speed bumps, dips in the road, and aprons were a real bitch. I had to approach them at an angle. Every trip added a new scrape to my airdam and/or bellypan. I found myself driving around like it was an old Packard or something.
What really made it bad was the roads that should be the most fun (twisties) usually have some unpredictable dips in them. Sitting too low at a good rate of speed, one of those dips would take out the a/c or worse.
The mechanical risk and the lack of improved handling far outweighs the look of a low car, IMO.
And come to think of it, it looks much better than I expected sitting 15mm higher.
Old 11-06-2005, 08:37 PM
martin D
martin D's Avatar
Some are crap, the good one is a must have.
I'm sure sombody here on the forum will be able to help you out , J M you out there ???
Old 11-06-2005, 08:42 PM
JPTL
JPTL's Avatar
Martin, really 125mm all the way around?!
Old 11-06-2005, 08:46 PM
toofast928
toofast928's Avatar
JP nice bike, I had the 250. Tach it out too many times on the semi-knobbies.
y 928 became unstable at 90 mph with the front end at 148mm. Re-adjusted to 170 mm. Nice and calm now but hate the look of tall fender. Think the winter project will be installing the Eibach springs.
Old 11-06-2005, 08:59 PM
martin D
martin D's Avatar
Yes, it was like it when I got it. I will go for handling over ride quality any day.I would agree with you that it can be a pain to have to drive it so carefully on some roads.
IIRC lowering a car by 1" is equal to increasing the track by 2" s, anybody comment on that ?
Old 11-06-2005, 09:14 PM
BIMMERMIKE
BIMMERMIKE's Avatar
there ???
Martin, who is J M ? I'm ready for a set so not to bother other member here for simple stuff. I really prefer a paper WSM but a good printer can solve that issue.
I want to get familiar with my car other than standing in front of my engine bay or laying on my back studying the underside. The winter is coming here in the Toronto area, lots of downtime to play in the garage.
86.5 A/T meteor mettalic/blk 180k km
Old 11-06-2005, 09:34 PM
martin D
martin D's Avatar
Martin, who is J M ? ...............
I've just PM'ed you,
$250 for the 9 volume paper WSM's from the forum sponsors
Old 11-07-2005, 05:59 PM
Gnarly 928
Gnarly 928's Avatar
Rrally low and bump steer is an issue. I followed Mark Anderson's advice and adapted some 911 bump steer kits for use on my racer, which I run at about 115 f and 120 in back. Noticable, especially with the rather large slicks I run all around..(12.5" x 18"). Just a quick look at the front suspension and steering will show you that when the car gets set up real low, suspension movement with the altered angles on the steering arms/tie rods, etc, changes where the wheels point(without any steering wheel movement) better with that corrected, when the car is really low......This happens to some extent with a stock car also, but to a much lesser degree.
Don Hanson
Old 12-13-2005, 03:22 PM
drnick
drnick's Avatar
so 120mm in front can negotiate londons cart tracks (apparently) but what is the optimum difference front to rear for high speed autobahn type driving? im guessing that raising the rear will result in more downforce over the front axle as it allows the air to flow faster under the car, but by how much do you want the rear to be higher?
Old 12-13-2005, 05:21 PM
UKKid35
UKKid35's Avatar
Originally Posted by mark kibort
geeeezz.. we all know how low my car is 113mm front, and 135mm rear.
Mark, drive your track car in London and it will last about 100 yards, if that. I've damaged a Koni adjustable through bottoming out on London roads when I was at about 140 front - never again.
Nick's car is pretty low (though not as low as Mark's) and you can hear it fouling the bodywork when turning in on a minor gradient, it's great on the track though.
Martin - Guess what? I've now got both parts I need, arrived this morning, yet to check it out though...
Quick Reply: Ride Height, how low can I go in the front?
