Brake rotors do not warp!
Interesting discussion. Just to add to the mix, in the Volvo 850 world there is a very common problem with brake vibrations. Opinions vary on causes with one school of thought being that the 'warped' rotors are being caused by incorrectly torqued wheel nuts.
Another good site for a bit of reading material on rotors and breaking in new pads.
http://www.pagidusa.com/Pagidusapassenger.htm
Cheers,
Terry
'85 928S
Cheers,
Terry
'85 928S
If you ever happen to be channel surfing and see a NASCAR race where they have a wheel camera you will see the rotors turning red hot on those tracks where they use a lot of breaking. The heat involved can be intense and most metals can be warped easily by uneven applications of heat. The fabrication on exhaust headers tubes the process of welding causes the tubes to bend (which is why X pipes sometimes need a little persuasion to mount up the the exhaust manifold ) even when held in a fixed jig the uneven heat cooling is virtually unavoidable. Metal is far less solid than most people think. I had a front brake pad delaminate and the steel backing plate in just a few laps at the track went from being a flat 4 by 3 inch 1/4 thick to an L shaped 4 x 5 of 1/8 thickness or so as it extruded under the heat and pressure of braking !
[QUOTE=FBIII]If I'm not mistaken the early m6 and m5 BMW's had major rotor warping issues.
FBIII- Funny you mention that. I've owned an M3- E-30 and had the same problems, even with new rotors!
Originally Posted by James-man
Someone once told me that when you buy a new brake rotor, you should have it surfaced before installing - is this true?
Say I buy a set of Zimmermans from a big 3,4 or 5 vendor. Can I just put them on?
Can warping be detected with a straightedge? Anyone know what it generally costs to have a rotor turned?
As a supplier of gauging machines to the automotive industry I deal with the like of Bosch and TRW and the like. We supply machines to check out the dynamic properties of rotors. The pulsing of your pedal is a result of what is known as thickness variation (TV). That is how thick the brake plate thickness is as you measure it all the way around. The lateral runout (within reason) (which is what you would see if you put a dial indicator on the rotor and spun it around) is accounted for by the fact that the calipers float. What happens is that the natural lateral runout if excessive will contact the pad at the high point. This high point gets worn off and now the thickness at that point is smaller than the thickness around the rest of the rotor. This causes your pulsing pedal. So in fact using your brakes gently will have a tendancy to cause pulsing sooner. If you had a 1999 - 2002 jeep grand cherokee the brakes were made by continental teves and had a seal problem that did not cause the piston to pull back enough and caused this pulsing to happen in less than 20,000km. DCX changed to Bosch brakes as there was high warrentee cost involved. Having that knowledge I had the rotors and pads changed under warrentee 3 times in 3 years with 36,000km.
Point of this => use your Porsche as it was intended to be used. Big brakes for fast stops....eh!
Rod
Rod
I recently had GT3 brakes with a custom aluminum hat installed. Very nice package but I soon experienced serious vibration under hard braking. I had the rotors turned and removed about 10/1000 from the surface of the rotor and the vibration disappeared.
I think this was the result of an improper bed-in process by the installer. The pad material was bedded in inconsistently across the face of the rotor and resulted in vibration.
Rod
Not the first time I've heard this. How do I convince my wife.
Two other problems are partially rusted rotors and mismatched rotors. Don't Know what causes mismatch, but one rotor will always lock up first. turning will often but not always help this. Letting cars sit out without being driven can cause rust to form everywhere except under the pads. You can drve off the rust, but often those areas on the rotors become case hardened. this would no doubt contribute to uneven deposits. It is never a bad idea to drive a mile or so after heavy brake use. The so called cool down, not unlike first generation turbos.
Originally Posted by MrLexse
For the purpose of this discussion, I'm taking the position of "devils advocate". I'm sure most of the people responding to this thread know more about the subject of brakes/braking than me, but in trying to weigh the information I'm reading, I came across
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
This was the quote I was referring to. It's a strong statement coming from a reputable source. What do you make of it?
Owns the Streets
Needs Camber
Needs Camber
The old wives tale/internet lore I heard years ago was to drive
green pad/rotors gently for 50-100 miles. Then go out for a real
hard run with some good hard braking stops.
Is this a way to deposit pad material on the rotors evenly?
I'd liked to use my S4 brakes hard but hate the idea of pulling out
clumps of Hondas/GM/Fords/Nismo etc. from the rear bumper cover.
Ernest (NYC)
Ernest (NYC)
