928 Forum 1978-1995
Sponsored by: 928 Specialists
84S Starts, Dies Twice, then No Start
Old 06-23-2009, 07:32 PM
  #61
DANdeMAN
DANdeMAN's Avatar
You can see it here almost all inside the board.....
Old 06-23-2009, 10:39 PM
  #62
SharkSkin
SharkSkin's Avatar
Glad it was simple. When you pull the panel, push thatterrminal out and look at it there is a little barb that catches in the terminal block to prevent that from happening. You might want to bend that out a bit so it catches better.
Old 06-23-2009, 11:23 PM
  #63
DANdeMAN
DANdeMAN's Avatar
Yeah it was simple but hidden, cost me 2 weeks and $175 in part to get there.
It was not the initial problem but it was a major pebble in the gear so to speek.
Yes this was my finding when I took a closer look at it this afternoon.
That little barb was flat with the terminal.... Pushed it out and now it is very much "hoocked" in it's place.
Thanks for the heads up though.
Old 06-24-2009, 08:35 AM
  #64
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
Hi Dan,
My engine dying occasionally thread had the same condition on the yellow connector just to the left of yours. The little A3 and A4 locking tabs had bent back and no longer locked into the connector. When pushed out they clicked into place and seem to be holding fine.
Good luck
Quick Reply: 84S Starts, Dies Twice, then No Start
